show private-vlan
show private-vlan
Description
Displays information about all the PVLANs on the switch.
Syntax Description
Default
N/A.
Usage Guidelines
If the PVLAN is incomplete because it does not have a network or any subscriber VLAN configured, [INCOMPLETE] appears next to the PVLAN name.
The following example output displays all the PVLANs on the switch:
# show private-vlan
Name            VID  Protocol Addr        Flags                Proto  Ports  Virtual
Active router
/Total
Engineering
Network VLAN:
-Engr1         10   --------------------------------------   ANY    4 /5   VR-Default
Non-Isolated Subscriber VLAN:
-ni1           400  --------------------------------------   ANY    1 /1   VR-Default
-ni2           401  -------------------------------------    ANY    1 /1   VR-Default
-i1            500  -------------------------------------    ANY    1 /1   VR-Default
Ops
Network VLAN:
-Ops           20   -------------------------------------    ANY    2 /2   VR-Default
-OpsNi1        901  -------------------------------------    ANY    1 /1   VR-Default
-OpsNi2        902  -------------------------------------    ANY    1 /1   VR-Default
-OpsNi3        903  -------------------------------------    ANY    1 /1   VR-Default
-OpsNi4        904  -------------------------------------    ANY    1 /1   VR-Default
-OpsI0         600  -------------------------------------    ANY    1 /1   VR-Default
-OpsI1         601  -------------------------------------    ANY    1 /1   VR-Default
-OpsI2         602  -------------------------------------    ANY    1 /1   VR-Default
-OpsI3         603  -------------------------------------    ANY    1 /1   VR-Default
-OpsI4         604  -------------------------------------    ANY    1 /1   VR-Default
Sales [INCOMPLETE]
Network VLAN:
-NONE
-SalesNi1      701  -------------------------------------    ANY    1 /1   VR-Default
-SalesNi2      702  -------------------------------------    ANY    1 /1   VR-Default
-SalesI0       800  -------------------------------------    ANY    1 /1   VR-Default
Flags : (C) EAPS Control vlan, (d) NetLogin Dynamically created VLAN,
(D) VLAN Admin Disabled, (E) ESRP Enabled, (f) IP Forwarding Enabled,
(i) ISIS Enabled, (I) IP Forwarding lpm-routing Enabled, (L) Loopback Enabled,
(l) MPLS Enabled, (m) IPmc Forwarding Enabled, (n) IP Multinetting Enabled,
(N) Network LogIn vlan, (o) OSPF Enabled, (p) PIM Enabled,
(P) EAPS protected vlan, (r) RIP Enabled,
(T) Member of STP Domain, (V) VPLS Enabled, (v) VRRP Enabled
Total number of PVLAN(s) : 3
Platform Availability
This command is available on all platforms that support the Private VLAN feature. For features and the platforms that support them, see the Switch Engine v33.1.1 Licensing Guide document.
